Hello all. My first post here. I ran a search and didn't come up with any results so I apologize if this has been asked before.
I think my dads old Grasshopper 720k has a Kohler CH640. I can't tell exactly since the tag is trashed and I can't find any other markings on it so I went off of pics on google images.
The issue is that the rocker bolts are backing out and dropping the pushrods out. At a quick visual inspection it doesn't look like there was any other damage other than one rod getting bent. The springs and rockers look good and no other damage to the parts other than the bend. The rod ball ends are good too.
Can I put some loctite on the bolt or will that not hold? I need to find some torque specs too, but is there any solutions to keep this from happening again? One of the valve cover bolts already broke off so I'm not thrilled at the prospect of pulling the head off an old machine like this and checking it out, although I may have to.
This is probably going to catch some fire, but I'm going to bend the rod back into shape and see what happens until I can find some replacements. It's just bent with no kinks or other damage and I have some tools to get it pretty straight.
Thoughts on how to fix the backing out issue?
Thanks in advance.
Thanks in advance.
