Kohler 7000 Extremely Dark Oil
cruzenmike
Location
Michigan
As the title suggests, when I changed the oil on my Toro Titan at the end of this past summer, what came out of the engine was extremely dark. I completely understand that oil can and will darken over time, especially under certain operating conditions, but, I am inclined to believe that what I was experiencing is not necessarily normal, and here's why:
I purchased the mower new in the summer of 2024 with 0.0 hours on it. The engine was filled with oil from the dealer that shipped it to me. I checked the oil when the mower arrived (freighted to me) and used the mower for the remainder of the summer. Believe it or not, I only put about 5-6 hours on it as my lawn only takes about 35 minutes to cut and I have two other mowers that are used intermittently alongside this one. I do not recall whether or not the oil at that first (5 hour) interval was extremely dark or uncharacteristic of a first oil change, but it was not anything that concerned me at the time. Since the season was coming to an end around that first oil change, I went ahead and did a full tune-up and put the mower away for the winter. I used a genuine Kohler Tune-up Kit which included 10w-40 oil, Kohler Pro oil filter, spark plugs, fuel filter and air cleaner, which by the way, none of the replacement parts seemed like they needed to be replaced, but I did it anyway. I also make it a habit of flushing the engine oil at each change. (run, empty, fill, run, empty, filter change and fill).
Fast forward to 2025 and I began using the mower at the start of the summer and when Fall came it only had about 17 hours on it. I always believed in changing the oil at the end of the season so that the machine never sat with dirty oil in it all winter. So I go to do the oil change and what comes out, after only 12 or so hours of use since the last oil change, is the blackest oil that I have ever seen. I never started the mower in temperatures below 50 degrees Fahrenheit, the only gasoline that I use is 90 octane ethanol free and I only choke the engine the minimum that is required to get it going. I have never witnessed the engine smoking, not even when starting on choke, but yet the oil is so contaminated after only 12 hours of use.
Why I am concerned is for these reasons: I have owned many lawn mowers over the years, and I have not seen oil this dirty EVER, and I have gone twice as many hours in a year's time before oil changes on other machines. My Honda push mower probably clocked nearly as many hours as the Toro with golden yellow oil at the end of the season. My Exmark with nearly 500 hours on it would go 25 hours in-between oil changes and come out golden yellow at the end of every season. Hell, even my 1998 Craftsman GT with nearly 1300 hours on it, doesn't have oil that looks this dirty, even with all of the cold starts, and even further (time) in-between oil changes.
The only thing that I will note, is that there is something peculiar about this engine when I am starting and stopping it. It seems as if it does not want to start so easily. I will have it fully choked when cold (like I said, above 50 degrees, but "cold starts" nonetheless) and it will crank for about 4-5 seconds before firing up and then once I get it going I ease the choke down until it runs smooth. I have heard of some engines "liking" to be choked, but this does not seem to be the case as once it is running, it seems as if it wants off the choke right away. The other thing, which is possibly more concerning, is that when I shut the engine down, it comes to a very abrupt stop. I have never had a mower engine behave like this before. All of my other riders and zero turns would just smoothly wind down over the course of a few seconds when the ignition was turned off. I have owned mowers with Kawasaki (FR651V, FR691V and FX651V), Briggs (ELS24 and Magnum I/C) and even other Kohlers (KT725 and Command Pro CV22S) and I have never had it where the shut off seemed almost violent. It reminds me of when someone shuts off an old diesel pickup truck and the whole truck shakes as it ka-klunks to a halt.
My question for you guys (and gals if present), is, could there be something wrong with the engine that would BOTH cause the starting/stopping issues as well as causing premature dirtying of the engine oil? The machine is in warranty and I do plan to take it in first thing this next Spring, but I would like to have some sort of idea as to what I should be telling the Technician other than the "oil is dirty and it shuts off abruptly." Not that I want to tell the Technician how to do his or her job, but if there is a known failure that causes these symptoms I could at least elude to what might be wrong; point them in the right direction. Maybe it's just a valve adjustment issue, or compression not what it should be, maybe leaking seals/rings? Just looking for some ideas. Thank you.
I have a Kohler 7000 series and yeah, it does take a few seconds to start. Normal, I dunno, but doesn't seem to be problematic. I was able to fix this issue by installing a 1 psi electric fuel pump, and then It has been starting without even needing choke. And that abrupt stop is probably from how new the engine is, there is a ton of pressure in those cylinders, and it resists that spinning when shutdown. I can't tell if the dark oil could be an issue, but as long as no metal chunks, all should be okay? Your engine is still breaking in, so the first few oil changes may seem abnormal.
If you plan on taking it in, don't wait until spring. Do it now. When spring comes, the repair shops will be swamped.
Hello C.,
You forgot to provide us with the engine number information. I'll guess it is a Kohler. Toro does not make the engine.
Take it back to the selling dealer and have them document everything for record. They will need to perform a compression test and a cylinder leak down test.
All dealer shops have the resource/ ability to send out a used oil sample to a lab for testing and that can determine any excess internal engine wear factors.
Without physical testing all anyone else can do is take wild guesses.
What rpm do you run it at? Do you idle it around the yard to save gas? Maybe easier on the engine?
At this point all you have is to know that the choke is fully open mechanically. I don't know if using 40 weight instead of 30 would make a difference here. It sounds to me that it needs to be run. At this point you have fresh oil, so pulling a lab sample with zero or low hours does you no good. You can't ask a tech to analyze spark plugs with so few hours on it.
This statement has me curious:
"I used a genuine Kohler Tune-up Kit which included 10w-40 oil, Kohler Pro oil filter, spark plugs, fuel filter and air cleaner"
Was this a genuine Kohler Amazon kit? What was the kit number that was used?
So far, the only unusual factor is the "10W-40" oil. Most kits that I am aware of come with SAE 30 or SAE 10W-30 engine oil.
Waiting to hear back from the OP on this one.
Wondering if he still has the blades on when killing the engine?? Abrupt stop on the engine revs?
40 or 30 oil is not a huge difference. Still needs the proper oil.
Wondering if the ACR has left the chat? Would cause a hard start he never mentioned.
Dirty oil is excess carbon or someone left the air filter out sucking in dirt. Ring blow-by.....
Sounds like the engine cut off solenoid may be leaking, causing the engine to flood a little after shut down. This will cause blowby of the fuel past the rings and dilute the oil which will further damage the engine. A dirty or missing air cleaner could allow dirty air into the engine, so check to make sure it is properly sealing. I always put a thin layer of grease on bottom and top of filter media to improve seal.
Next time you change the oil, see if a magnet attracts anything to it. Pour the oil through a coffee filter and check for debris. Smell of the oil to see if you can detect any gasoline smell. Premature Black oil is a sure sign of blowby caused by possible bad piston rings, or they have not seated yet with so few hours on the engine.
Correspond with the dealer via Email, and save all copies in an archive file so you can prove you did report the problem during the warranty period. Sometimes a dealer forgets to document such things and will deny ever hearing them. As always, CYA with paperwork.
