Koehler Courage 20 starter probs
I personally have never rebuilt that starter. Although, what problem are you having with it?
Check it is not the wiring on you mower by jump starting off your battery directly to the starter motor , both the + & -
Check that it is not your battery by doing the same using your car battery ( car engine off )
Nine times out of ten the problem is a bad battery cable or dirty grounding point.
AFAIK, Kohler do not sell starter parts so you need to get them from an auto electrician.
Try berts tests. If the starter is really pulling too many amps you probably can't fix it. True high amp draw is usually shorted windings in the armature.
