Koehler Courage 20 starter probs
Scrubcadet10
Moderator
Staff member
Keep in mind your truck battery has more cranking Amps than your mower battery.
When I need to I get my brushes and drives from Stens.
Interesting
Stens do not have any Kohler starter parts in their Aus catalogue, just complete starters.
I took the battery out hooked the cables to my pickup battery. Zing, started right up! Getting another battery on Monday. T
BEfore you do that double check the mower battery leads by jumping to the mower battery terminals .
A battery will be cheaper than a starter but make sure you fit a mower battery or a motorcycle battery & not a general car / truck battery.
And put a sealed one in there .
Mower batteries are physically stronger inside to compensate for the lack of suspension and the excessive vibrations.
