reynoldston
- May 23, 2011
- 92
- 5,705
The only advantage the Bucket engine had was you could work on the internals without removing the block from the mower. That is if the engine stayed together long enough to require working on the internal components.
Not much of a advantage when you have to strip the block and have the cracks welded at a welding shop. The last one I did it ran into a 600 dollar repair.
