Kawasaki FR691v
macdog73
Where did you get that .002 spec ? Don't want to burn any valves. They should set same as mine between .005 - 007
Kawasaki repair manual .Go to Kawasaki.com/FR691V/repairmanual
7394
I personally spoke to Kawasaki & they confirmed the .005 - .007 for the FR Kaws.
And my local Dealer who repairs them, also confirmed the same.
I know the online manual you have, cause it's same one I have. But those specs are not correct according to my 2 sources & I think Kawasaki should know their engines.
Anyhow that's what I set mine to, .005 on the intakes & .006 on EX, quiet as a kitten. Whatever works for ya.
Luffydog
Look at outdoorpowerinfo.com go to engine specs there is a list of most engines and specs.
The problem is kawasaki & Honda publish their tune up details in metric units.
Then people see 0.20mm and think .020" not .008".
Luffydog
Yes I think that where the confusion is coming from
macdog73
saw both metric and us mRe: Kawasaki FR691v
however I am going to change adj. to the NO's you gave to see what happens Also the fuel filter I bought for this engine is an updated one .No one had the filter I took in. seems it is an outdated filter
macdog73
I went to outdoor power FR691V specs clearance listed was 0.05 to 0.10MM ( 0.0020-0.0039 ) in specs section again same numbers .not trying to tell you that you are wrong but this is what I read.
