robmorren2
- Sep 23, 2020
- 9
Looking for some help, I'm a John Deere newbie. I started dabbling with a complete rebuild of a mower deck, and a rocker gasket and head gasket replacement -- so that's how inexperienced I am.
Here is the problem I'm having right now with my L118. The lawn tractor jerks momentarily, slows down then takes off like something catches, and you can hear a clicking/popping noise while it happens. It happens much more regularly when turning tight circles. It will happen from time to time in a straight line as well, but it seems to smooth out more when going straight and will get up to speed like it normally would. Forward and reverse both work. In this video, I am going in a tight circle, as if I was rounding the base of a tree ...
Thanks in advance for your help!
