Lawnranger
- Apr 18, 2012
- 671
So how does one go about checking the timing...?
Remove the blower housing and related parts. You will probably have a large nut or bolt holding the flywheel on and you will most likely have to remove that retainer. Look straight down from the top of the crankshaft for a keyway. There is also a keyway on the flywheel. The two keyways should be lined up with a key. If you see one keyway in one position and the other keyway in another position, the timing is off due to a sheared key. The loose blade could be a result of hitting something and shearing the key in the process.
Report back with what you find.
