I have a JD F525 with 600 hours. It started leaking oil from the seal on the bottom of the engine. I replaced the seal and it still leaked so I thought I had a bad seal. Replaced the seal again and ran it this time before bolting the electric PTO in place. It wasn't leaking. Once I bolt the PTO in place, it starts leaking without the engine running. Any thoughts or ideas would be greatly appreciated. Thank you!
