bluefitness
- Sep 16, 2012
- 13
- 46
This is for a Toro pace lawn mower.
I wasn't getting any compression. The intake valve was stuck open. I freed it up and worked it back and forth. I noticed it looks like it is at an angle to the block. The odd thing is that if I rotate the valve, the higher side is always to the left. It is almost like the stem is at an angle and not bent. It lines up with the pin in the access hole. What are your thoughts?
