Why not try using a screw type hose clamp (say ~3/4" dia) and clamp the choke cable directly to the tubular handle right next to the choke control lever? It's cheap and might be worth a try ?
A simple zip tie will work.Please see the attached picture. My choke cable sheathing moves from the housing each time I try to use it. IF I hold it in place, it works, but I would like to fix it if possible.
till it stretches & gets looseA simple zip tie will work.
This would work. I'd say make sure you can insert all the way in after cleaning, apply JB weld to the end, maybe a little in the tube, insert, and crimp again, after set maybe put some heat shrink to it.Pull the sheathing out, clean the cable and the interior of the crimp material well, apply JB weld and insert it back in leaving it for 12 hours. Before using spray the cable sheath full length with your favorite lubricant.
