You just missed out, the Surplus Center had 300 of them a month or so ago.
You might like to search there they may have a few left.
I bought 20 of them for 1/4 what they cost down here.
Stens do a copy well down here they do any way & also both filter elements.
As for rejetting, a load of cods whallop.
On a vehicle that does 10,000 rpm you might need to worry about it but on a governed engine that goes up to a whopping 4,000 rpm, restrictions to the airflow is minimal.
When you have a quick think about it the new filter has around 4 times the surface area of the std filter.
Honda tried to stop people fitting snorkels to their 160 & 190 engines by claiming they needed rejetting and making the kits 1/2 the price of a replacement engine.
Fitted dozens of them withut any jetting changes with not a stick of a problem, except the filters don't clog so I get less service calls.
Probably contravine clean burn exhaust regulations because the engines run a poofteenth richer but not seen problems with any of them.
Just be careful what tubing you use.
I use convoluted tubing from Tractor supply shop, for connecting remote tractor filters, not real dear and conforms to curves.
Just make sure it will not suck in.
Suction pump tube will also work quite well but is a bit stiffer & harder to route around bends.
If you are worried about running rich, buy a Color tune from Gunsens  UK and check the burn before & after you fit the filter.
