I will bet the moving linkage on the bottom of the tank is gone and the belcrank and linkage at the carb. Not an easy fix.
You should have some idea of correct speed. Run it at 3/4 throttle. Be sure to check/change the oil.I recently got hold of a very hold and rusted chipper/shredder. It's a craftsman model# 247.797851, I believe from 1990.
Previous owner said it hasn't been used for years, but it did run fine before that. I cleaned the carburetor, replaced the spark plug and lo and behold the engine fired up.
However, this is when I noticed the engine has no governor. In the attached pictures, you can see where the governor rod is supposed to be, there is simply a bolt.
I figured the previous owner removed the governor on purpose and ran the engine by manually adjusting the throttle.
My only worry is, how do I know I'm not running at too high rpm? Is there an easy way to tell you are running at slow enough rpm to be safe?
