you can get a flange bushing or flange bearing for your pulley if the bearing you have is damaged.
You can also get pulleys that have bearings already in them...
Post a picture of the pulley, lets see what else you have.
Slammed solution to give you a mounting stud will work... you just have to mount the correct hardware on that stud to end with a working piece.... :smile:KennyV
