As you can see in the picture the depth Bigger so the backside of the coil is the exhaust manifoldThe important part of the coil is on the open end - if it fits up to the flywheel that's all you need really - does the length stop the cover from fitting up? Wouldn't recommend grinding on the coil , might change up the cover if it's touching off .
Yes they are hitting the intake manifold actually the exhaustLike Star mentioned, are those genuine Kohler parts? Kohler has been using the 24 584 36-S since 2003 and while they are physically larger than what they replace, I've never known of them not fitting. I assume they are hitting the intake manifold? Can't grind on that.
Our local Kohler dealer wanted $100 for one coil versus two of them for 36 bucks on Amazon yes they are a bit bigger therefore it’s hitting I believe the exhaust manifold pipe but alsoLike Star mentioned, are those genuine Kohler parts? Kohler has been using the 24 584 36-S since 2003 and while they are physically larger than what they replace, I've never known of them not fitting. I assume they are hitting the intake manifold? Can't grind on that.
The length is making it hit the exhaust manifold even though the part is supposedly correct and I’ve called all around it’s definitely bigger than the original. The left side fits fine but the right side the back corner which is circled in the picture rubs up against the exhaust manifold or intake manifold I’m not sure which one I just need to know if I could grind a little bit of that park that circled in the picture to make it fit it wouldn’t be much probably a couple millimetersThe important part of the coil is on the open end - if it fits up to the flywheel that's all you need really - does the length stop the cover from fitting up? Wouldn't recommend grinding on the coil , might change up the cover if it's touching off .
It’s not the cover it’s hitting it’s the exhaust or intake manifold pipe I wouldn’t be grinding the front part that touches the flywheel it would just be the back corner a couple millimeters grind it off to fit from stop hitting the manifold pipeThe important part of the coil is on the open end - if it fits up to the flywheel that's all you need really - does the length stop the cover from fitting up? Wouldn't recommend grinding on the coil , might change up the cover if it's touching off .
