I have to say that I miss the drop-down box associated with the "BACK" button. Unless I'm missing something, all you can do is click "BACK" one at a time - you can't select a page to go "BACK" to.
Next to the magnifying glass in the addy bar...the dinky arrow...you can go back as far as you want.....:biggrin:
Still finding the tricks to this myself..........The 'pinned' bit is fluff......I've had trouble with sites freezing while doing normal stuff.....
Example: I open LMF through the pinned taskbar icon. Great. Loads right up. Forum's dead - nobody's replied. I go to refresh the page to see if any LMF icons lit up - it just sits there and has the spinning thing in the tab......and spins....and spins......four minutes go by. I get mad. I close it, re-open through the pinned icon on the taskbar.....*BING* it opens right NOW. Go through the regular IE opening/navigating procedure to get to LMF? Not a hitch all night. Does it for Ebay and FB, too.
So, just don't rely on the 'pinned' stuff......if you even use it at all......:thumbdown:
