Identifying an older Murray?
celticpiping
From the engine number ie will be a 95 or 96 model.
Take a photo of the faded ID tag at an angle.
Pop this into a photo editing application then invert colours of if it has it "make negative" filter.
This will make a negative image and he nubers will pop out as if by magic.
Carscw
I have around 60 Murray mowers.
This is a 96 I will get you a model number tomorrow that will work for you.
These mowers make the best off road racing mowers.
celticpiping
wow, would never have thought of that..
I'll give that a whirl!
celticpiping
thanks much.
I can tell you the 1st 2 digits on the engine "CODE" are 95
someone said that might indicate the year..
celticpiping
alrighty, I found it!
46904x92A
bertsmobile1, you're my hero!!
thanks much
now, onto fixing it...
Rich
A trick I picked up when working for a contractor who had a police forensic contract,
Although in those days it was a case of wet under developing the film.
Digital photography is good for things other than the kids taking selfies.
