Been reading about zero turns for a few weeks and did not want to get the very cheap big box brands in the 2-3 k price ranges.
I found someone that was only 10 minutes from my house, that bought this diamndback new, last year - its a 2022 model with only 18 hours on it. He moved to a new home and now only has a small yard and cant use this worldlawn anymore. I called 3 dealers in my area and they said that these sell for around $5900 out the door right now. I got this 2022 model for $4250.
It has the kawasaki engine, which I was told was very important, because some model years had a different engine and had issues. I weigh 240 lbs and stood on the deck and the deck did not have any bend/ give at all. The deck is very heavy duty built. It has the servicable hydro drive units that are of solid quality , dual gas tanks , 1 on the left side and 1 on the right side for weight balance . I checked the pulleys and they seemed very heavy duty . I am aware that some of the metal/ frame is built overseas but those items seem much better built then usual residential grade stuff.
I also like the manual foot operation to raise and lower the deck along with the pin adjustment on the console to adjust deck heights in 1/2 inch increments. The gas gauge is an easy to see, window float style. I like this type of stuff because its simple and easy to use.
I was told to use 20-50 weight kawasaki oil that has the zinc additive in both the engine and the 2 hydro drives , but im not sure if that is to be used just for initial break in or to use that oil permanently.
Mower seems to run strong , is fast and it has 4 heavy duty springs under the seat for comfort.
Hopefully I can get at least 10 years of use out of it for my 3 acres of land, without any catastrophic issues/ breakdowns.
