Auto Doc's
- Sep 7, 2024
- 23
- 1,951
Hello Greg R.,
Governor tension spring broke or came off? Without the engine running, move the throttle to the fast position. Locate the governor arm and see if it has tension on it. If it does not, the spring is not working.
Item #9
www.partstree.com
Item #9
PartsTree - Home of OEM Parts for Outdoor Power Equipment
Parts lookup and repair parts diagrams for outdoor equipment like Toro mowers, Cub Cadet tractors, Husqvarna chainsaws, Echo trimmers, Briggs engines, etc.
www.partstree.com
