HI YALL,
I am a first timer looking for input with some of the more seasoned techs out there. I gave a small shop my left trans from my RZT 50 CUB CADET to rebuild and $450.00later, he said it was done, after having torn it down and rebuilt twice. When I picked it up, it ran worse than when I dropped it off to him. Plus, I footed the bill for all the parts of which were 2 filters, one for my trans, one for him to keep in stock, as well as the 4 thrust bearings (2 of which went into my trans and 2 for his stock). Having forgiven him and picking my mower up, I decided to tear it down myself. After dis-assembly, I discovered he had not even changed, not to mention, clean the existing filter. Sooo, I proceded to order the 2 new pumps, after carefully inspecting all other parts, and reassembled it. After loading it with 40 wt non detergent and 1/2 pt tranny fluid, I purged it, adjusted the linkage and took off mowing. It ran like a new machine for about 20 minutes then started slowing down in the left with the right being ok. I'm not sure of what I can do to make a fix and thought I would reach out. By the way, the small retainer pin in the mail pump shaft was installed properly, after I got the heck of how to keep it in place. I'm confident of reassembly, but am looking for guidance on how to keep the trans running consistantly. Any ideas?
