As Bert said we are not there. We need the equipment model number from the serial number tag. There are usually two belts so which is breaking.Won' start wont get much in the way of useful help
We are not there drinking your beer and looking at your mowers
So we need detail and no detail is too insignificant.
So what do you see, hear smell ?
what happens from the time you bum hits he seat till you get off & kick the mower .?
He said it won’t even click when trying to start. Which is why I suggested checking all connections,safety switches etc. I should have said to start with the battery and don’t forget the ignition switch. I agree with needing more information. Model and serial number and which belt etc.As Bert said we are not there. We need the equipment model number from the serial number tag. There are usually two belts so which is breaking.
I do suspect you got one of the 42" Raptors that I have seen a lot of drive belt breakage.There is few common problem that causes this but we need to know if it is the drive or deck belt that is breaking.
As for not starting. Does the starter even spin the engine or is it not even operating? Each is a different problem.
Make sure the handles are all the way out. inspect the neutral switches that are at the bottom of each one and check that they are closed. I had the bolts drop out of one switch and that stopped me cold. Both switches have to be closed, in order for the starting circuit to engage. Of course, you could have other electrical problems, such as a bad battery, a broken/missing wire, a bad ground, or even a bad switch. That you have it on both of these makes me feel you might not be fully in neutral.I have 2 Hustlers and have the same problem on both with an additional problem on one. They will not start. Won’t even click. And one of them keeps breaking the belt when it was running. Any suggestions please.
