djdicetn
- Sep 3, 2012
- 12
- 2,193
Just bought the 52" Raptor. It is an upgrade from 10 years of residential tractors. My last mower was a used Deere L100 I bought off a neighbor that hurt his back after buying and quit mowing. It was in storage for years. Got a great deal and it was barely used. Thought I was in heaven using it over old Craftsmans that I had prior. My dad is no longer able to mow, so I have picked up his yard and widow's next door. Bought the Hustler after lots of research and because of the 48mo SAC. I can't believe I didn't sell everything I needed to so that I could buy one of these years ago. The mower runs great, cuts great and is very sturdy so far. I am slowly learning not to turn too quickly in certain spots after knocking over my birdbath and clipping some trees. I have wired a DC socket into one of the rear pockets to use for a small foglight so that I can mow after sunset. Also charges my iphone for long cuts. I am well past the breakin period and have already done the initial oil change. Only issue there is clearance for my big hand to remove the filter and the awkward feeding of the oil drain hose. I have also replaced the seat with one from Tractor Supply that is adjustable and has armrests. It was much cheaper than Hustler's upgrade seat. Overall I think this is the best mower for the money, and I hope to get many years out of it. I find myself mowing too soon just to get outside and drive it around. The large muffler controls the noise and the Kawasaki just purrs as I cut.
Future upgrades will be a 3 way hitch and maybe some bedliner on the platform for traction and scuff control.
Only real complaint so far is that the deck choked on me while cutting wet. I solved the problem by mowing with the ejection guard up half way. I have rigged a piece of rope from it to the right throttle handle allowing me to lift it as i go through tight squeezes and before I store it.
I would like to hear any other Redneck mods that others have made.
tnmorris,
Here ya go...get rid of that foglight and do it right!!! Here's a link to my redneck mod that'll make mowing in the dark a breeze:0)
http://www.lawnmowerforum.com/build-yourself/18564-ztr-light-kit.html
