Hustler Raptor SD PTO switch ripped off
Hustler usually put their wiring diagrams in their parts book
So go to the Hustler > support > manuals and download your manual
Pull the plug off the back of the PTO switch and jump the plug with a short wire with a spade terminal on each end.
On the subject of the plugs pull them off and push them back on tight .
If you have problems working out which wires to jump them post the full mower details off the ID tag so we can pull up the right wiring diagram
OR "Print" the page with the wiring diagram on it as a PDF then export or save it as a JPG then include it in a post as a photo.
Hammermechanicman
With the key on if you engage and disengage the PTO switch with everything in the mowing position do you hear the PTO clutch engage?
Come on the wiring on mower is one of simplest you will find and still have any safeties operating.
According the cross reference of the 776476 PTO switch this is the pin out. Matching colors indicate continuity between terminals.
Can be be as simple as the PTO connector plug in backwards if no locating blank was used. Either way the kill relay should be operating as well as the start relay even if the wrong PTO switch was installed.
