- Nov 29, 2014
- 24,995
The gator blade is a mulching blade.
The back wings throw the grass towards the center of the blade so the grass will stay under the deck. And get cut 4 to 5 times. This is the reason the grass cut clumped up under the deck. They are not high lift blades they are mulching blades. The reason they do not clog the shoot up as much as regular blades. Is because they do not discharge the grass as fast or as much.
This is because the grass being discharged is in smaller pieces so when a clump hits the chute, it breaks up and passes through insted of bridging.
Much like the difference between tipping out a bag of sawdust comparred to a bag of curls.
