Hustler height decals with numbers instead of letters
Carlosgcruz99
  • / Hustler height decals with numbers instead of letters
I made this replacement for my Hustler Raptor SD 54" - not sure what other models it fits
this was made to replace the letter system for deck height that made no sense to me on my own mower
Solvent printed and laminated approx 3.5 x 4"
$3.50 with shipping
I will have these until May 14 and then again when I get back from vacation around June 7th resume
Do you
wbrandhorst
$3.50 with shipping
i want to buy
Does the machine cut exactly at those lengths per your sticker?
Anyone measured their cutting height on some real grass?
michigan_Rapter sd
actually I have a 3" block that I put under the blades when I level my deck and have the setting at 3" when I do that adjustment every spring or as needed. so NO the factory settings will not be exactly as the numbers are on the decal - they were made to be very close when I purchased by mower and hated the letters system. I have since sold my solvent printer and laminator and have to farm out the production so cost went up considerably. this was a project for my personal need and others said they wanted the decals. since I had bariatric surgery, until I recover max's garaj mahal has offered to take care of anybody still wanting the decal.
No mower cuts the height shown on the deck which is why a lot of makers mark them with letters
Even walk behinds are subject to the density of the grass, the toughness of the grass and of course wear in the lift linkages & improper deck adjustments.
Add to that unless the deck is dead level it will be cutting a scallop shape because the front is lower than the sides .
Turbine55
$3.50 with shipping
Do you still have the height decals for the hustler 54”. I would like to get one
