hustler fastrac 44''
And I don't think it will be enough to run the electric PTO and recharge the battery so you will most likely have to hook up to a trickle charger after each mow.
Micah Haarhoff
Get it to me, in Australia ?
You should have one of these
The red wire should be DC + and goes to the battery or the ignition switch Terminal A ? check your wiring diagram.
The black wire is AC and goes to the headlights.
I dont have a wiring diagram and I dont have head lights on this zero turn
Micah Haarhoff
Im pretty sure it's the second one that's the one that best compares out of the 4 best i can tell From the wires anyway
Micah Haarhoff
Do you thing i need to get you some pictures of the wires?
Micah Haarhoff
Page 42 is the electrical scematic but im terrible and reading those:ashamed:
gabowman
Sounds like you need to find a small engine mechanic locally that works from his yard to help you or give you advice after seeing what you have.
Micah Haarhoff
I would like to do it myself if at all possible:smile:
