Husqvarna 455 Rancher coil question
If you send a pic of the coil attached but not fitting, they should refund your money and you keep the coil. I'd grind the center leg till all 3 legs are equidistant and see if it works.
They are refunding my money--I thought of grinding the center leg--I may try that if all else fails! I can't believe this has become such a deal!!!
