Husqvarna 455 Rancher coil question
fred93
If you send a pic of the coil attached but not fitting, they should refund your money and you keep the coil. I'd grind the center leg till all 3 legs are equidistant and see if it works.
They are refunding my money--I thought of grinding the center leg--I may try that if all else fails! I can't believe this has become such a deal!!!
The key here is the OP chainsaw is a 455 and not either one of the listed engines.
Scrubcadet10
Moderator
Staff member
Good God, i've been reading it 445.....?
OP disregard every single thing i said as they were in regards to the 445 saw, my apologies.
