Husqvarna 2042LS Oil Filter
larrypac
I have a Husqvarna 2042LS riding mower and would like to change the oil filter but even on the Husky website it is difficult to find a part number, which I would hope I could cross reference to something I can find without going to a Husky dealer. I have the owners manual which just tells me when to change the filter but there is no part number given. I spent 30 minutes this morning searching and came up empty. Can anyone advise me how to find a filter for the mower? Thanks, Larry
Scrubcadet10
Moderator
Staff member
You will need the model number of the engine, which if its a Briggs and Stratton will be stamped into the valve cover.
Omak1
The Walmart Supertech is ST3614 or Fram 3614 will work on your mower.
oil filter will be an engine part not a mower part
FWIW I use a B&E large or B & S small on everything that has a unified thread
For metrics I need to keep 3 but the bull of engines all have unified threads
The only real difference between any of them is the physical size
Tecumseh filters are the smallest, Kohlers are the thinest & B & S are the biggest
They all quote different micron sizes but that is insignificant as the sizes are all within the the acceptable variation in commercial filter paper .
