- Nov 29, 2014
- 24,995
When I get into these situations I instal a spark tester or Colour Tune
Clamp the saw by the bar making sure it can not move ( some times I also support the engine end with a stand
Then it is a case of starting the saw & watching the spark tester
Some times I even video it so I can play back at a slower speed
I am looking to see if it stops sparking then stops spinning or sparks all the way to shutdown
If the former then the coil & wiring is suspect
so the next step is to unplug the coil at the coil to see if it is the coil or the wiring/switch .
If the latter then I know it is a fuel problem
