When I took off the carb, I took it apart and cleaned the entire thing. Bowl off, float off. Everything was spotless.
Like I said, It'll start with half a pull with a shot of starting fluid. After I have it running and I shut it off and then I try to start it right away, it'll start without any fluid, When I let it sit for 5 minutes or longer, then it will only start with a shot of starting fluid.
Thanks again,
Pat
I have the exact the problem as said here. I wish I can some direct answer with direct experience like Pat's. thanks
