philipgonzales3
- Mar 12, 2020
- Threads
- 1
- 10
So Initially when I'd try to start the mower it would run for 2-3 seconds and turn off. It seemed like it would blow a puff of air right as it died. Of course I did not get any videos of the original symptom.
I drained the gas and filled with new gas. No change in behavior.
I tried cranking it like 30 times and mower would just run 2-3 seconds and then shut itself off.
I recently replaced the spark plug less than a year ago. I made sure the boot was tightly on the spark plug and decided to look at the carb. I have never messed with a carburetor before and this has an auto choke system. I of course have no idea how things went together before I took off the two bolts to the air filter housing.
Can anyone by any chance confirm this is the correct movement? No idea if these parts are together correctly lol.
Now it will run but with very low idle. Not sure if I made the problem better or worse lol.
It seems I can get the mower to rev up pretty well by pushing on the bottom arm that manipulates the choke? Vroom Vroom?
Any ideas on what I should do next? ANY help is greatly appreciated.
