So I recently acquired a mower from a neighbour who over torqued the carb bolt into the head and sheared the bolt off inside the head. He tried to drill it out and damaged the side of the housing, I found what looks to be a similar engine with the same model number. However it’s been removed from a leaking power washer but runs well. What problems might I run into doing this?
