mikeypizano Active Member Joined Feb 11, 2012 Messages 94 Mar 11, 2012 #1 Are the blades for the HRX the same as the ones on my HRC? Sent from my HTC Flyer P512 using LMF
mikeypizano Active Member Joined Feb 11, 2012 Messages 94 Mar 12, 2012 #3 JoeM(GA) said: no they are not Click to expand... Didn't think so but I found out what I wanted to know. The center hole on my HRC blades is 20MM so I can get a 20MM bolt to use for balancing.
