mikeypizano Active Member Mar 11, 2012 #1 Are the blades for the HRX the same as the ones on my HRC? Sent from my HTC Flyer P512 using LMF
mikeypizano Active Member Mar 12, 2012 #3 JoeM(GA) said: no they are not Click to expand... Didn't think so but I found out what I wanted to know. The center hole on my HRC blades is 20MM so I can get a 20MM bolt to use for balancing.
