Are the blades for the HRX the same as the ones on my HRC? Sent from my HTC Flyer P512 using LMF
mikeypizano Active Member Joined Feb 11, 2012 Threads 11 Messages 94 Mar 11, 2012 / HRC blades same as HRX? #1 Are the blades for the HRX the same as the ones on my HRC? Sent from my HTC Flyer P512 using LMF
JoeM(GA) Well-Known Member Joined Jul 10, 2011 Threads 0 Messages 193 Mar 12, 2012 / HRC blades same as HRX? #2 no they are not
mikeypizano Active Member Joined Feb 11, 2012 Threads 11 Messages 94 Mar 12, 2012 / HRC blades same as HRX? #3 JoeM(GA) said: no they are not Click to expand... Didn't think so but I found out what I wanted to know. The center hole on my HRC blades is 20MM so I can get a 20MM bolt to use for balancing.
