HRA216 Decompressor
kknh3
I've been having trouble with my Honda HRA216 bucking really badly when I pull the starter rope. After some internet research, I suspected that the decompressor was not working correctly. I disassembled the engine and pulled out the camshaft. I anticipated finding the spring broken or some other issue with the decompressor. However, other than a little wear as pictured, it seems to be fully functional. Would the little bit of wear on the low speed lobe be enough to cause the decompressor not work and result in bucking when pulling the starter rope? If not, what should I look at next? Thanks in advance.IMG_9327.JPGIMG_9319.JPG
That was it. I remember setting the valve clearances in the last year or so. Somehow the stud that the exhaust valve rocker pivots on had backed out about 1/8". Once I tightened that down and reset the clearance, it starts much more easily. Thanks for the help.
klnh3: What exactly do you mean by this statement? "I've been having trouble with my Honda HRA216 bucking really badly when I pull the starter rope." From a engineering perspective that spring and assembly is there to advance and ****** timing throughout the RPM operating range. So I don't understand your use of the word "Buckling"
