Hi, I have a 1989 HRA216 Commercial mower. The mower itself is in overall great condition and built like a tank but as it sits right now the blade is always engaged, No matter the position of the upper hand lever. I have taken a look underneath and there is some movement in the cable when the lever is activated. Underneath, the cable reaches the 'stop' position fully. When the upper lever is engaged, the cable underneath moves about 0.5" away from the 'stop'.
Usually when the BBC system goes the blade is unable to be engaged, this is the opposite!
Is this normal, or could it be possible that someone before me has manipulated the BBC? Just curious... I had a look for some parts if need be and they do seem to be available, but very pricey. I am not sure it is worth the $$ to fix.
