I rebuild old Maytag 1/2 hp gas engines as a hobby. I want to power various things with them using v-belts. My problem is finding a way to start and stop the action without stopping the engine. As these engines are constant speed, a go-cart type centrifugal clutch won't work and I would like to find a way other than using an idler pulley to (make and break) the tension on the belt. I know that I can do this using an idler pulley, I'm just looking for a cooler and different way to do it.
At this time I am trying to power a corn grinder with one of my Maytag's. Some of the first old riding mowers had a small transmission (about the size of a wall mounted pencil sharpener) mounted on the deck to the right of the seat. As best as I can remember this had a forward, neutral and reverse. I am wondering if this might work. There is also a pulley type clutch that is mounted on a jack shaft. This pulley has a handle. When it is rotated it causes the pulley to engage and thus start to turn whatever you are powering. (This type of pulley may be a form of a sprag clutch) Most sprag clutches are made for industrial uses and are very expensive. I have seen these used to power ice cream freezers powered by John Deere hit and miss engines. The only supplier for these that I can find is asking over $399.00 for this pulley clutch. This would make the clutch cost more than the Maytag engine, the Corn Grinder and by speed reducing gearbox combined so it's a no-go on that.
In my case there would be a pulley on the Maytag and a belt that goes to a pulley on a jack shaft or to a speed reducing gearbox, then from there another belt to the drive pulley on the corn grinder. If the jack shaft is used then I would reduce the speed by the pulley sizes used.
Possibly some type of manual pto clutch would work. It can't be an electric clutch because there is no electric power associated with the Maytag engine. I am wondering if any of you have any other thoughts on how I can do what I want to do or if if you know of a supplier for a pulley clutch other than the guy that makes Ice Cream rigs for sale to companies that sell ice cream at outdoor events etc. I am not planning to sell anything so everything that I am doing is all outgo and no income. I am building this for a display associated with the antique engine club that I belong to.
Hopefully the attachments are of my corn grinder being laid out shown only with a gearbox and not a jack shaft and pictures of the kind of clutch I would like to find. However ANY other of your ideas are welcome.
Thanks for looking.
Thanks for looking.
