grumpyunk
- Jul 13, 2015
- 0
- 151
To get the engine to 'hydrolock' from being tipped on its side/end would take some time UNLESS your rings were pretty well worn out. Hydrolock is the situation where there is liquid in the combustion chamber that prevents the piston from fully traveling to TDC(top dead center) and which may cause physical damage to the connecting rod/piston if the piston is forced to attempt compressing the liquid. It would take a good quantity of oil leaked past the rings into the combustion chamber to prevent the piston getting to TDC. Good quantity being on the order of 1/4 cup of oil, roughly. It could happen, but you'd have to have it sitting for some time to allow the oil to seep past.
One thing to remember is that you want to have the carburetor side 'up' if you tilt your mower to drain the sump. If carburetor side down, you run the risk of flooding the engine with fuel.
tom
tom
