Cusser
- May 3, 2019
- Threads
- 16
- 246
OK, here's my current solution. I drilled a hole, attached a 5/16" eyebolt to the handle; I peened the inner surface of the handle in, and replaced its padding with some new pipe insulation, so I can still pull the wagon manually without the end nut digging into my hand.
Then I circumcised the bolt head for the upright mount on the lawn tractor so the eyebolt could slip over.
