How to attach my garden cart to my lawn tractor ?
Cusser
OK, here's my current solution. I drilled a hole, attached a 5/16" eyebolt to the handle; I peened the inner surface of the handle in, and replaced its padding with some new pipe insulation, so I can still pull the wagon manually without the end nut digging into my hand.
Then I circumcised the bolt head for the upright mount on the lawn tractor so the eyebolt could slip over.
7394
Then I circumcised
Ouch, Got me on that one..
Your mod is a "Winner-winner, Chicken dinner"....... That will do the job for sure.. (y)
sgkent
As the song says, "Paint it Black"
Cusser
  • / How to attach my garden cart to my lawn tractor ?
This worked quite well !!!
Cusser
This worked quite well !!!!
SeniorCitizen
When i need to attach items not often used i find a Clove Hitch knot to be a quick solution . A modified Clove Hitch can be tied to quick release . No knots to fight . Unties as a shoe string does .
7394
Yep, that will do it.
Cusser
My 2022 solution has worked for me still.
7394
Cool Beans.
wickedgoodoutdoors
Cusser-
Just add a cheap tow-ball hitch like I have pictured here on mine, that's how I pull our wagon & etc. Handle slips right over the ball.. I did same on my Craftsman decades ago as well.
I did the same thing with an old scrap metal bracket and a 2 " Ball so I can pull my duel axel garden cart or single axcel boat trailer. Just drill 4 holes and 4 bolts & Nuts.
