reynoldston
- May 23, 2011
- Threads
- 92
- 5,705
As I said on a earlier post wheel weights and chains.  I have the same Wheel weights 55 LBs. each.  I have tryed it without chains but that didn't work you need both.  I only put  10psi air in the tires.  When I first got the 12 hp Wheel Horse I tryed to push the snow with a blade bur couldn't mover nowhere as much as with the snow blower. With a blade you would have to add more weight. At one point I was going to install tractor style tires but was told whey are no good for snow.  I could really use a little more HP when the snow gets heavy.
