justinrohrer
- Jun 3, 2020
- 9
My Honda HT3813 riding mower turns off within about 5-15 seconds of startup. At that point gas pours out of what I believe is an overflow(connected by a tube to the top port of the carb). The only way to make it run at that point is to put it in choke, although it runs roughly and still spews gas. I've tried installing an inline fuel filter and cleaning the carb with a cleaner(I believe it was Goof-Off), and that seemed to help for a while, but tonight it had the same problem again. It seems that the gas is being directed from where it should be going and into the overflow. I appreciate any help you can give.
