- Nov 29, 2014
- 24,995
If you can get hydrochloric acid this always works
1) degrease the shaft, multiple times till you can not see any oil slime on the top of the wash water
2) dip in a SMALL BOWL of acid and leave it there till the reaction slows down.
Do this outside because the bubbles are hydrogen gas BANG BANG BANG and some acid vapour which will collect on bare steel parts in your shop & start them rusting.
invert the engine with some angle iron under the support boss
Hit the shaft with an air hammer
10,000 litle blows a minute works a lot better than a big wack with a hammer every 3 minutes.
