soundchasm
- Aug 7, 2018
- 1
- 17
"I looked at pictures of the transmission... it looks pretty simple inside. I think I would try turning the trans pulley while holding the wheel or drive shaft to see if you can get it to slip. If one gear slips, try another, I think it’s got 3 gear sets if the pictures I saw were correct. Considering how expensive they are I wouldn’t buy a new one until you KNOW yours is bad. From what I also read, cable problems are very common. Maybe grab the end of the cable with vice grips to see if pulling it “more” than it’s adjustment range gets it to move. Also maybe carefully open the trans and look around. Stripped gears should be pretty obvious. I think there is a shift fork / pins that engage each gear set. "
There is 1st, 2nd and 3rd. I got nowhere in all three gears. I'll go give the cable one hell of a tug to see if that works. Since none of the gears work, it's apparently not a single gear.
The trans can be had for just north of $100, so that's not too bad. I'd hate to take it out, take it apart, discover a problem, and then not have a replacement. Of course I'd love to take one apart and see what's in there.
What I recall from the test was that the handle to engage the drive seemed extreeeeemly soft. It never "bit", if you know what I mean.
In terms of an unexpected benefit, when I was cleaning the assembly that does the height adjustment, getting all the oxidation and crap off that lever really freed up the adjusting mechanism. It moves easily now and before I had to use pliers and screwdrivers to get the thing to move. So we've got one point on the scoreboard so far. ;-)
Thank you. We're gaining on it, but just more slowly than we thought at first.
