bwdbrn1
- Nov 23, 2011
- 15
- 383
You wont' need to worry about pulling the flywheel off from the PTO end. If that happens, Honda does sell a very complete line of replacement engines.:biggrin: When the blade holder let's loose, it will happen in one of two ways. It will either come off slowly, or suddenly pop off. Just to let you know in case it's the second.
We haven't discussed this yet, and in case you haven't done so, do drain all gasoline and oil out of the engine before you start moving it around at the angles you'll need to to get the blade holder off. I'd also recommend you put the bolt back into the PTO shaft, loosened a bit, for the gear puller to push against, and not just the open end of the PTO.
Robert, would you recommend putting a gear puller on the blade holder, applying some pressure on it, then striking the end of the gear puller shaft with a hammer to get the holder off? Not like you're going to ring the bell at one of those carnival he man sledge hammer things, but similar to the method recommended for getting an aluminum flywheel off of the GCV160.
