Hey!
I am in the process of disassembling the GXV140 engine on my mower to get at the piston, and I have discovered that I can't get the lower cover off - the mounting plate for the blades and spool for the belt (which are welded together) are in the way.
Backstory: The mower has given over a decade of useful service, and just recently I was told that the mower is 'not in a runnable state' and the engine was 'beating itself up'. Being the handyman, I pull the mower and discovered there is a slop somewhere in the linkage between the piston and crankshaft by as much as 15 degrees at TDC and BDC, and as few as 3 at any halfway points between this. Since the piston is still captured by the crankshaft (I.e. it doesn't just push the piston up, it pulls it back down as well), I am assuming that the connecting rod hasn't been broken, and that either the end caps are loose, or there is serious damage where the connecting rod mates the piston.
Problem is, I can't get inside the block - the cover is located 3mm right behind the spool/blade mounting assembly (which itself will not budge).
Can anyone help? Does anyone even understand what I am rambling on about?
Thanks a million!
-CM
Thanks a million!
-CM
