- Nov 29, 2014
- Threads
- 64
- 24,718
SimpleWell, I find it strange that an internal combustion engine manufacturer does not recommend changing the oil, as it deteriorates, loses its lubricating characteristics, whether due to mileage, downtime or hours of use.
As for gearboxes, without contact with fuel and the outside environment, it is more than logical.
As for the level, regardless of the combustion engine or gearbox, it must always be inspected and topped up during its useful life...because if the volume is insufficient, lubrication is impaired and the engine's useful life is reduced.
They did a Vox Pop and found out that most home owners hate doing oil changes, so they eliminated it
Back in the days when a mower could last 50 years if maintained properly, maintenance was important.
Now days when 2 years is considered a reasonable service life and by 5 years they are worn out or in Cal no longer EPA compliant why bother to change the oil.
People conflate car & truck engines with mower engines
They only similarity is the parts have the same names
IF your car needed an oil change every 50 to 100 hours you would be doing it almost weekly
Most mowers will happily fun for several years on the original oil without mush in the way of adverse effects
Unlike pressure fed lubrications systems, full splash does not allow contaminants that can cause excessive wear into the journals because there is not the space for them to get in.
This is why the old side valve engines would run with treacle in the sump.
And yes they would run better but mower engines are very low stress engines
My 125 cc 2 stroke premix motorcycle has 14 Hp and will push me along at 60 mph on the flat all day long running at 6000 rpm
My 250 cc 4 stroke full splash 1927 motorcycle will do the same running at it's top speed of 4,500 rpm
Yet my 500cc mower engine stuggles to cut the grass
