meestahmarc
- Apr 17, 2018
- Threads
- 5
- 18
Hi. Picked up an awesome billy goat power rake for $50 for my home use. It was solid but not running. I cleaned it up and am putting it back together, but ran into a few question marks...
1. The black isolator between the carb and the engine, which side face the engine? One side has a circular flange and holes, other side is flat.
2. I have a carb rebuild kit that came with several gaskets. I can figure out which one goes between the metal air filter bracket and the carb. There are two screw holes that match up with the gasket, but seems like there are other holes which the gasket doesn't account for, would cover the holes.
3. How do I change the oil without removing the engine? Do I just tilt the machine over and try to make a little mess as possible? Which side would be better? I assume I could do either side as long as I'm on level ground.
4. Gas tank has some cracking on the outside, but it seems like the tank holds pressure andndoesnt leak.
Sadly I wanted to post pics, but all my file sizes are too large. Annoying.
